Anyone have advise on replacing decals that are peeling off on a corrugated aluminum sided travel trailer? Only you tube videos I could find was doing it on smooth sided fiberglass. I assume the alumi...
i replaced the 32” wide Jay-Flight decal on the front of mine. The ribs in the aluminum did not affect the installation at all.Be sure to remove the old decal and adhesive. A careful use of a heat gun makes quick work of the old decal removal. I got some plastic razor blades at a boat place also so the paint on the siding wouldn’t get scratched.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,352 PostsLatest Activity: Jan 29, 2025
