DeWat
Apr 20, 2013Explorer
ktmrfs wrote:
If height is a problem look into the "waterstick" resin/brine water softeners. they lay horizontal, we have one and it works great and is easy to recharge. The disadvantage is capacity in grains. Less than the ones others have mentioned, so it will need more frequent recharging, but it only takes about 15 minutes to recharge and uses less water during recharge. They also make a unit with iron control.
http://www.watersticks.com/p.htm
Thanks much! From what I have seen thus far, I thought that all the water softeners were upright units. This certainly looks like an answer where I don't have to run the extra piping.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,351 PostsLatest Activity: Jan 13, 2025
