MPI_Mallard
Apr 24, 2019Explorer
I have five dometic awning shield's on my fiver and the one the dealer installed on my slide has the powder coating flaking off at both ends, I'm in the process of replacing the two awnings and three slide toppers so I called dometic and asked them if they would replace the shield that the paint was failing and was flat out told no as it was out of warranty. it's obviously a case of shotty prep at the powder coating shop and as i'm about to spend a couple of thousand dollars on more dometic awnings you'd thik they would look after this shield,,, not! So I'll simply re-paint the shield myself, get the awnings from Tough Topp and never spend one dime with them again!
Red Green; Do a good job and they'll tell ten people,,,
Do a bad job and my wife will tell a hundred,,,,
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,353 PostsLatest Activity: Feb 14, 2025
