Colorado__5's avatar
Colorado__5
Entertainment Center Upgrade
Has anyone ever attempted to upgrade their old analog entertainment center to a digital format? I have a 2003 Winnebago Minnie with it's original entertainment center in it. Needless to say the thing does not work. I attempted to connect the original antenna to an led flat screen and it would not receive any signal.
All wiring is coax cabling which is not compatible with the hdmi connections on the tv. We also have a small tv in the back bedroom that has a coax running to the front of the RV that when switched used to send signal to the rear tv for viewing.
I'm curious if anyone knows if I can pull an hdmi cable through the walls to the rear of the RV using the coax cable as the snake.
Also anyone that has attempted to upgrade their RV please chime in on things you did, things that worked and things you would do different.
Here is a picture of the Entertainment Center.
Click For Full-Size Image.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,369 PostsLatest Activity: May 10, 2025
