Tom_Barb's avatar
Tom_Barb
eternabond
we are in process of resealing the seam of our coach, we removed all old calking, sanded smooth the area 2-3" each side of th seam, wiped it down with acetone and applied eternabond tape, This has got to be the best sealing tape I've seen, when the area is dry, and clean when this stuff touches your not getting it off.
  • Ron3rd's avatar
    Ron3rd
    Great stuff, if you follow the instructions to the letter, it's a one-time repair as noted above.
  • Make sure you roll it good with a wallpaper seam roller or other similar device per the instructions. Otherwise you may find yourself having adheasion problems down the road. I put it on my trailer quite a few years ago and it is still holding up well and no leaks.
    Barney
  • I've been using Eternabond for several years. It's a one time repair.
    If installed properly, it will last a long time.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,353 PostsLatest Activity: Mar 10, 2025
