- TNGW1500SEExplorer
6.2Superduty wrote:
I also have a shower problem. Wife says its on the wrong side of the trailer.
I wish it was on the door side too so we could use it with a hose to wash down the porch or the dogs paws. We've never used the outdoor shower on any RV we've ever had. I thought about changing it but it sounds like work. - TNGW1500SEExplorerDo you use a shower? If not you could cap it off and cover the hole with a door like this one:
Search Google for "Boat Hatch" - mobeewanExplorerIf the original housing is not reusable and you were unable to swap the new parts from the new housing to the old housing and you are unable to get a new housing the same size as the original you are going to have to make an adapter plate large enough to cover the old hole with a new hole cut to the size of the new housing.
Some possible choices of material would be stainless steel plate, aluminum plate. Another would be King Starboard.
King Starboard is a plastic material that comes in various sizes and thicknesses and can be purchased from places like West Marine or www.boatoutfitters.com. It is used for various boat repairs and I think it might also be used for building dashboards and consoles. - 6_2SuperdutyExplorerI also have a shower problem. Wife says its on the wrong side of the trailer.
- Dutch_12078Explorer IIIs the original housing still usable? Perhaps just move the fittings to the old housing?
- beemerphile1Explorer
Henry Wall wrote:
The hole in the wall of the trailer is to big for the shower
Way I see it, you have two choices to do it right.
1. Buy a trailer with a smaller hole.
2. Buy a shower that fits the hole you have.
To do it redneck, fill the extra space with some plywood. - Henry_WallExplorerThe hole in the wall of the trailer is to big for the shower
- Baileys_BuddiesExplorermore info ?
- mike-sExplorerPark the trailer on a large stack of blocks.
- ScottGNomadIf it's just the hose, can you swap the old one to the new one?
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,352 PostsLatest Activity: Jan 20, 2025
