Groover's avatar
Groover
Apr 22, 2019
Flexible Solar panel performance
Can I get some feedback from people that have had flexible solar panels 2 years or more? I would like to know how they are holding up, performance and visual. It seems to like they are a lot easier and safer to install than rigid panels but I have heard that they don't hold up well.
  • Almot's avatar
    Almot
    chuckbear wrote:
    Scratches develope from dirt, weather, leaves, tree branches, scrub brushes and just about anything else. They also degrade from UV and will eventually look like they are fogged over. Chuck
    Yes. This is clear plastic cover, not a glass like on rigid panels. When there are no leaves and branches, like in desert, there is a lot of dust accumulation. Sand particles can be abrasive.
    IMO, there is rarely a scenario in RVs where a rigid panel could not be installed.
  • Most installs I did were on fiberglass tops and soft covers like biminis. There were always issues with dirt getting under them and discoloring the fabric and abrading the fiberglass. They will need to be removable to clean under them. Not an issue and 10 knots, but could be at 65 MPH. I can imagine a lot of movement at those speeds.Chuck
  • Chuck,
    Did you see any problems with the surface the flexible panels were mounted to? It seems like there would be a LOT of heat transferred to the roof or deck or wherever they are mounted.
  • Scratches develope from dirt, weather, leaves, tree branches, scrub brushes and just about anything else. They also degrade from UV and will eventually look like they are fogged over. Chuck
  • chuckbear wrote:
    I installed and used flexible panels in the marine industry for decades. They do not have the same output as solid panels and scratch easily so the output is degraded even more. They also don't have the same longevity. I stopped installing them. Chuck
    What sorts of things scratch them or more importantly am I likely to encounter the same things with my RV? It is rare for me to get on the roof of mine. Longevity is exactly what I am asking about. Would you please elaborate? How long did they last and what killed them?
  • I installed and used flexible panels in the marine industry for decades. They do not have the same output as solid panels and scratch easily so the output is degraded even more. They also don't have the same longevity. I stopped installing them. Chuck
  • I'd also love to know.
    Planning solar addition, but not in a hurry.
