lawrosa
Feb 15, 2018Explorer
Nice. As a plumber I can appreciate that..
That check valve is thermostatic... I believe 90f they open to circulate and close at an upper temp..
These I install to get instant hot water at the fixtures..
I was toying to do a hydronic heat set up like that with the water heater and a fan over coil. But the water heaters are too small... Not enough btu's..
Whats the amp draw on that pump?
Good job.
Good job.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,352 PostsLatest Activity: Jan 23, 2025
