Vintage465
Aug 15, 2021Nomad
Hot Water Re-Circulation Pump
I happened to have all the corroplast under belly off of my trailer a while back so I figured it would the right time to make some "inside the belly upgrades!
It takes this much water to get hot water to my shower
So I tapped into the hot side of the shower faucet thru the access.
Then I installed this little food safe, hot water recirculating pump
All completed it looks like this. I did install a check valve in place of the plastic valve you see between the pump and the cold water inlet of the water heater.
There was a switch outside the bathroom that was used to turn on the light in the bathroom. We always turn the light on in the bathroom using the switch on the light, so I re-purposed that switch to turn the re-circulation pump. I turn the pump on for 30 seconds, then turn it off and I have instant hot water at the shower. Pretty snappy since we do mostly boon docking.
