otrfun
Apr 08, 2021Explorer II
Even if you used the same BMS and cell configuration for =>two parallel battery packs (to increase overall current), wouldn't you potentially run into charge/discharge balance issues between battery packs after a certain number of cycles? Talking about the same balance issues the BMS's are supposed to help prevent from occurring between the individual cells in each battery pack. If this did happen, one should be able to resolve it by top balancing the battery packs themselves, right?
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,353 PostsLatest Activity: Feb 14, 2025
