deltabravo's avatar
Feb 18, 2021
Installing magnets for the cargo doors
My truck camper was built before RV manufacturers were using the little magnets to hold open the cargo doors. The clips were a nuisance to use, so I added magnets.
I used double sided tape to install them rather then drill more hols in the walls.
Here's a video of the project
  • I also installed the magnetic catches and also used VHB tape. I prep the surface first with the 3M primer as well.
  • Interesting, I had to add some to our cabinents since the doors did not stay shut when moving. You can buy the magnetic latches tho and they are cheap, less than $1.50 each:
    latches
About DIY Maintenance
