JhawExplorerJun 03, 2017Inverter helpHi guys, I'm wanting to set up an inverter so I can run power off of my battery bank and solar. I had a 2000 / 4000 peak inverter that I had been using, but was tired of not having my outlets work...Show More
time2rollNomadJun 04, 2017with just 2 batteries you need to get closer to 1000 watts max.Not all inverters are made for the battery connected to the ground. Try removing the batteries from the RV to isolate.Some inverters only provide half the rating to each outlet.Ok and this is a good time to post the exact make and model of inverter(s).
About DIY MaintenanceRV projects you can tackle on your own with a few friendly pointers.4,353 PostsLatest Activity: Feb 14, 2025
