Hi guys, I'm wanting to set up an inverter so I can run power off of my battery bank and solar. I had a 2000 / 4000 peak inverter that I had been using, but was tired of not having my outlets work...
When I installed a 1000 watt in my 5th wheel I connected the plus and minus to the battery and grounded to the chassis. Wouldn't work. As soon as I disconnect the ground the thing works perfectly. I use it with adapter and connect it from the inverter out to the power input for the trailer, powering the whole house.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,353 PostsLatest Activity: Feb 14, 2025
