mikebo's avatar
mikebo
Keeping LEDs stuck in fixture
I'm replacing all the incandescent bulbs with smd led panels in the fixture. The 2 sided tape on the led panels doesn't seem to want to stay stuck. I've heard this is a common problem. What have you come up with to keep the LEDs tuck in the fixture?
  • The two sided tape that comes with the leds is useless. Buy a roll of good 2 sided tape and re-do the led panels.
  • All of mine have been up for a couple of years now. What I did was clean the surface of the fixture real good with rubbing alcohol and a clean paper towel a couple of times & let dry a couple of minutes b4 applying.
  • I used a hot glue gun -- Lot less expensive than 3M tape -- Bill Willard
  • X4 on 3M tape. Just used it on applying cork board to a wall and it's great stuff
  • 3m tape.. in 5,10,15 pound... if you use the 15 pound tape.. and wish to remove.. get a long screwdriver to PRY it off.
    glue stick .. also works well.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,352 PostsLatest Activity: Jan 20, 2025
