SidecarFlip's avatar
SidecarFlip
Nov 15, 2017
LED Headlights...
Owning an older truck 97 F350 Ford Diesel, back then the only option for headlights was Halogen bulbs and, while they work pretty well and I can see pretty well with them, I wanted to upgrade to a better system
I looked pretty hard at HID lights but the amp draw is steep plus they have to warm up and I don't particularly like the emitted light. Oncoming vehicles with HID lights I find irritating to look at and always have to look away
so...
Superbrightleds.com was running a special on LED retrofit bulbs and had my size for the '97 Ford.
Install was pretty easy, I had to remove the batteries to gain enough access to the backside of the headlight to get the units in because they have large heatsinks on the backside. That also entailed removing the LED bulb itself from the base to install the OEM lock ring. I also had to locate the ballasts, which I zip tied next to the headlights themselves
What a big difference in illumination. On low beam I can see farther down the road and much better to the sides too (great on a 2 lane country roads I drive on alot. The emitted light is very white, not yellowish like the Halogen lights were and road signs and paint stripes really pop now.
Wondering if anyone else runs LED headlights and if you do, do you like them. Most all military vehicles now run LED lamps because they last 10 times as long as Halogen and 3 times as long as HID lamps plus they draw very little current.
Amazing technology.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,353 PostsLatest Activity: Mar 10, 2025
