EricKim's avatar
EricKim
LED Side Marker Lights
On the bottom of my RV I installed these LED side marker lights, I bought them from AUXITO. It's about as easy as it gets, drill the hole, insert the rubber grommet, push in the light and make your connections. The 3/4" provide a nice amount of cool white light and with both a power and ground wire you are free to mount them anywhere on any surface material. The power draw is so low it's not going to affect switching or supply load and they last! So far my lights are burning bright as ever after two Michigan winters. Make sure you read the instructions well, mine had WHITE grounding wires so double-check before you connect them, your instructions will tell you.
  • Dutch_12078 wrote:
    Why would anyone install "cool white lights" when side marker lights are required to be amber by the NHTSA?
    Read his post again. He says he installed them on the bottom of his RV, which means they are accent lighting (aka underbody lighting)
    However, calling a white light a "side marker light" isn't really an accurate term. White lights aren't side marker lights, per FMVSS 108
  • 2112's avatar
    2112
    ScottG wrote:
    2112 wrote:
    Be Sure To Drink Your Ovaltine.
    Great reference! (Took me a minute)
    :B
    Ralphie screams It's a crummy commercial
  • His profile says Boston. Then he mentions 2 Michigan winters in his post.
    :B
  • Why would anyone install "cool white lights" when side marker lights are required to be amber by the NHTSA?
  • JaxDad's avatar
    JaxDad
    Hmmmm, a new member posting an ‘infomercial’ including naming the site they purchased from on their very first day here.
    Sure looks like another member of the SPAM ‘BOT brigade to me…….
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,352 PostsLatest Activity: Jan 19, 2025
