centerline's avatar
centerline
mini teardrop marker lights
Im not sure if this is the most appropriate forum for asking, but I have an '07 weekend warrior 5th wheel, and it has 3 small LED teardrop marker lights (red) on each side, mounted to the rear of the fender skirt... there are molded in pockets in the fender where they attach.
I recently lost the tread off of a tire and it took the lens's off the lights.
does anyone know what brand of lights they used on these trailers? or where to get replacements... the lights are 3" long, 1.3" wide and about 3/4" high.
thanks
  • worth a try maybe when I had my WW I went through all the lights at the truck shop None were the right size or shape.
  • jackxclan wrote:
    those lights were WW specific I havent seen any after market lights that match.
    http://www.weekendwarriorgear.com might be your only option.
    thank you... I found the ones I was looking for here https://www.ebay.com/itm/Red-LED-Teardrop-Marker-Light-Chrome-Cab-Roof-Marker-Clearance-Light/371264223784?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
  • those lights were WW specific I havent seen any after market lights that match.
  • Look at one of the other lens and get SAE or Manufacturer numbers. Then post that information.
