popeyemth
Feb 24, 2014Explorer
Low point drain mod
This was a simple mod after the brainy trust here told me the size of the Pex lines-1/2inch
Easily replaced with 1/4 turn shut off valves. If you don't have or can't find one with a " male" end use "close union" to adapt it. Reuse the plugs from the old fittings in the other end of the valve to keep road dirt and mud-dauber wasps out of it.
Remove plug, open valve to drain for winter and flush for spring.
No need for wet sleeves anymore !
Moderator edit to re-size picture to forum limit of 640px maximum width.
