Dog_Trainer
Dec 18, 2015Explorer
kellertx5er wrote:austinjenna wrote:
Doesn't hot water freeze faster then cold water? Thats what I was always told
No. You need better references.
Jan 9, 2013 - Hot water freezing more quickly than cold water is known as the Mpemba effect. So, why does the Mpemba effect occur? First, all water evaporates, which means that the liquid (water) "disappears" and becomes a vapor, or gas. Hot water evaporates at a much faster rate than cold water.
How is that for a reference. Maybe it is you that needs to check your references:)
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,352 PostsLatest Activity: Jan 20, 2025
