TARDIS_TIME_TRA
Sep 03, 2014Explorer
MAXXAIR FAN MATE BRACKET FAILURE
We recently had a visit from prospective Tiger RV folks. I washed the Tardis from top to bottom to make a good impression on them. In the process I noticed the Fantastic Fan Cover (MaxxAir Fan Mate)seemed to be loose. After closer inspection I found 3 of the 4 mounting brackets for the MaxxAir Fan Mate cover were broken or severely cracked. If you haven’t checked yours recently you probably need to at least once a year or every time you bath your RV. Attached are the before & after repair photos. I had to cut one of the nuts off with a metal cutter. None of the parts removed were reusable. To make sure I got the right mounting brackets I purchased them at our local RV Center. One more trip & we would have lost the whole cover, to say nothing about possible messing up someone else’s vehicle. Check yours out before your next RV trip…The Tardis Time Travelers.
rear bracket cracked completely
Hinged side Both cracked - see below
new brackets installed
fixed (lock down) side--------------------------------------hinged side
