rhagfo
Jan 02, 2017Explorer III
My Cheap Heat install
Well decided to go with the "Cheap Heat" system in our 5th wheel.
I did the install as a DYI, have done enough electrical work to feel comfortable with the high voltage work.
I read all the documents on line and the clearance needs, well I new it would be a snug fit.
I ordered the kit which is very complete with exceiption of the high voltage parts. I spent about another $150 for the necessary high voltage parts, and other needs.
This is the major parts I bought;
Square D QO 30 amp disconnect cabinet
Square D QO 30 amp breaker
Ground bar for 30 amp disconnect
Square D Home line 20 amp single breaker
15' coil of 10/3 with ground wire
25' coil of 10/2 with ground wire
2'X4' piece of heave sheet metal (I needed to extend the duct a bit).
The instructions are very clear and complete, I have it rigged so that in Spring, Summer, and Fall if 50 amp service is not available I can changeover to operate on a 30 amp shore connection. This would take about 10 minutes to move some of the line voltage connections.
I found even though I had improved the seal between the furnace and floor once the install was done the furnace worked better, with better air flow on gas. This was due to the old design the hot air really didn't have good air flow over the heat exchanger it only partly passed over it before going down into the duct.
So we are Currently dealing with temps in the high 20's at night and the 5,000 watt (17,060 btu) output is keeping us at 68 degrees.
This is the furnace under the sink location with a home fabricated 3" duct extension between the OEM furnace and Cheap Heat exchanger.
This is the 3" duct I built out of heavy sheet metal, would have been nice to have a sheet metal brake!
This is the 30 amp disconnect and the control box.
The best part of all the Gas / Electric switch!
Sorry for any typos and weird typing posted from my iPhone.
