Farmboy666's avatar
Farmboy666
New cabinet doors to open up dead space.
My cabinets over the dinette had 2 doors and blanks between and at the ends. You had to move what was in the doorway to get around to the dead space.
I knocked out the blanks and made larger doors from 3/4" plywood.
I changed the hinges to the top and installed pistons to make things easier then got the bright idea to cover the doors with maps. There is a place close by that bought thousands on USGS maps when they went digital. I found the area I grew up in and covered the frame first.
Then with a second map I covered the doors to line up with the frames.
Installed some pulls.
There was a slight learning curve but close to hanging wallpaper.
About DIY Maintenance
