ADK_Camper
Apr 12, 2019Explorer
Cabinet Modifications
My water pump is located in a cabinet behind a fixed panel. To access the pump for winterizing required removing four screws. I eliminated the screws and substituted magnetic cabinet latches to make removing the panel easy. It turns out this is a favorite hangout for mice. Now I can easily remove the panel to place/check traps for the unwelcome visitors.
This is a before picture showing the fixed panel at the bottom. The top shows a tambour door I made to close off an otherwise open cabinet. The door is made from screen molding glued to a piece of canvas.
I attached panel molding to the original panel to cover the screw holes and add some style. A drawer pull at the top allows me to just pull off the panel when needed.
Here you can see the magnets attached to the cabinet frame, and the catches attached to the back of the removable panel.
This picture shows the tambour door opened with a two drawer cabinet I made to fit inside. These are our "kitchen junk drawers" where we keep pens, pencils, tape, scissors, ruler, scratch pad, playing cards, etc.
