- sjturboExplorerThanks Tom. I'm actually looking for the actual post so I can pm the author.
- 2oldmanExplorer IICan't find it. Did you reply in that thread?
- diveman52ExplorerBe careful with solblvd.They sell a lot of B grade panels. Be sure to read the description.
- sjturboExplorerUnfortunately not. I thought it was in Woodall's but I surf wayyy to much, so I may be wrong.
- 2oldmanExplorer IICan't find anything using '285' or '45v' as search terms.
- sjturboExplorerThanks for tryin'. Maybe it was a dream:)
- wmosesExplorerIn situations like that, this is usually my first guess ... "maybe I dreamed it ..." ;)
Go to Google and try this search string (cut-and-paste into the search box):
forum: (("285 Watt" OR 285W OR "285 Watts") AND 45V)
Do you see the post you are referring to? - Chris_BryantExplorer III would think it would be 48 volt, not 45 volt.
Not that it matters much, but.... - BarneySExplorer IIIHere is the only post that I could find in the archives that mentions 285 watts.
Here are the results of a search of the archives on 48 volt.
Hope this helps you a bit.
Barney
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,352 PostsLatest Activity: Jan 20, 2025
