jamnw's avatar
jamnw
Program LED awning strip
Does anyone know how to program the "DIY" buttons on the remote? I'm in MB for 4th and would love to flash RWB.
  • The DIY (do it yourself) key, when pressed for the first time, will enter the DIY color mode. You can adjust each individual color brightness with the 6 keys shown above. However, if another key is pressed it will jump out of DIY color mode without saving your settings. In order to save the color which you have just created, you must press the same DIY key which you originally selected once again within 5sec. The next time this key is pressed, it will display the color which you saved the last time. There are 6 DIY keys, so you can save your favorite 6 colors/brightnesses
  • Thank you. So I guess you can't program a pattern? Like red/white/blue.
  • Yes you can program a pattern as well, on my remote there are a few DIY keys, one of which is a DIY Key3 for three different colors.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,352 PostsLatest Activity: Jan 19, 2025
