Bodine57's avatar
Bodine57
Question about lamps in class A
I have a 2007 Fleetwood pace arrow and want to upgrade my bulbs in my Lamps in Rv anyone know what led bulb can replace the bulbs that are in there now. Thank
    What bulbs are in there now?
    Pull one out and look at the base.
    They are either a BA15S base (1141 bulb) or a T10 (921 / 912) wedge style base.
    Those are the most common 12v bulbs used in RV light fixtures.
  • Hi Bodine57, go on M4 Products web site and they will assist you in choosing the correct led bulbs. I relamped a 2005 diesel pusher by replacing the 7 overhead fluorescent bulbs with there LED bulbs and dropped my amperage load from 7 amps on the driveway to 4amps. then tore out the Norcold and put a Samsung residential fridge in, which dropped the amperage down to 2 amps plugged in on the drive way. M4 products have great tech support.
  • Bodine57,
    Take one to a lighting store. Or post a picture here. Mine were mostly 1156.
    I replaced only the most used lamps.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,418 PostsLatest Activity: Sep 12, 2026
