Vintage465's avatar
May 29, 2017
Quieter Water Pump
I have a SureFlo water pump in my trailer. It is rubber mounted and hooked up with flexible water line on the inlet and Pex-ish on the outlet. I am not real impressed with how much noise it makes and was thinking of doing the following. Either or both....Rubber mount a mounting plate/board so the rubber mounted pump is "suspended" on a rubber mounted platform. Then I was thinking of enclosing it in an insulated box for more sound deadening. I recall when we sold Boles Aero(almost spelled that "arrow"!) Travel trailers they had a special little cabinet (actually a cabinet within a cabinet) that the water pump resided in. I don't really recall how quiet it was. Or............Is there a pump that is known for being quieter?
thank!
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,358 PostsLatest Activity: Apr 03, 2025
