โJun-27-2017 04:22 AM
โJun-27-2017 06:29 PM
โJun-27-2017 04:46 PM
wtmtnhiker wrote:
I used mineral spirits on a 5th wheel that I had and it made the rubber pucker up and wrinkle. Wouldn't denatured alcohol work just as well?
โJun-27-2017 02:27 PM
โJun-27-2017 09:17 AM
wtmtnhiker wrote:ksg5000 wrote:
If you end up tearing the rubber roof suggest you patch with Eternabond. I use a rockwell sonicrafter with special flexible caulk removal blade (http://multifitblades.com/flexible-scraper-blade-271.html).
Got lucky and did not tear the roof but there was a small tear under the old vent already. I caulked it but the tube says it does not fully cure for 30 days so I assume I should wait the 30 days before covering wit eternabond?
โJun-27-2017 07:54 AM
โJun-27-2017 07:46 AM
โJun-27-2017 06:55 AM
โJun-27-2017 06:47 AM
โJun-27-2017 06:10 AM
rhagfo wrote:tnedator wrote:gbopp wrote:
You can use a heat gun and plastic scraper to remove the old caulk.
There is also a Caulk Remover available.
I just remove the loose caulk. Clean the remaining caulk and apply new over it.
Eternabond will stick to the old caulk. Just clean the area well before applying.
How "delicate" is the rubber roof? I'm just wondering since you recommend using a scraper.
Stated Plastic scraper used with great care.
โJun-27-2017 05:48 AM
โJun-27-2017 05:39 AM
โJun-27-2017 05:20 AM
โJun-27-2017 05:04 AM
James,Gail & Pancho
2005 georgie boy Pursuit
โJun-27-2017 05:03 AM
