Anything can be made, it only depends on how deep your pockets are. Being that you want frames and glass both curved complicates the issue. I would hazard a guess that flat frames would not work on a curved surface.
Bring one of the windows that you want to be copied to a glass company that does architectural work. They will take a 3d contour of it and then they can make it any size or configuration and opening you want. Being that it is a custom build, you will probably see a 2k to 3k bill for a set of windows. I presume you will need one for each side and that is why I said set.
2020 Keystone Cougar 22RBS, Ram 1500, two Jacks and plenty of time to roam!
The difference between genius and stupidity is that genius has its limits. A.E.
Good Sam Life Member
