- jplante4Explorer IISeveral threads about this recently. One running now in the class A forum.
Member erniee in Texas is the forum expert. He does glued down engineered hardwood. Does some nice work. - ksg5000ExplorerAllure flooring is a popular product used by many to replace carpet - lots of threads/pics on this forum (use the forum search feature). It's not expensive, easy to install (many do it themselves), and seems to hold up well (5+yrs in my rig). Worth a look.
- Bill_SatelliteExplorer II
Grey Mountain wrote:
We want to replace the carpet in the front area of our 39' pusher with wood or simulated wood flooring. Is this a job a qualified carpet/wood floor installer could do, or is there something different about such installation in a motor home?
Thanks and stay warm
GM
A qualified installer could do the job but most won't touch a MH as it does take a LOT more cuts and nooks and crannies! They will have no idea what to do with a slide-out if you have one so that can be a serious issue. If you have any plans to travel anywhere near TX anytime in the near future then you should make an appointment with Ernie and enjoy the results!
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,352 PostsLatest Activity: Jan 19, 2025
