Sort By
- BobboExplorer II
Ed_Gee wrote:
According to the product description of his current charger converter, it does have Bulk, Absorb, and Float stages of battery charging. It also has battery type selection for wet, AGM, and Gel type batteries. It appears that he does not need to replace his existing charge converter.
I'll agree that the documentation does say that. However, the WFCO is notorious for never going into bulk mode. He needs one that actually does what the documentation SAYS it does. Ed_Gee wrote:
Maybe. There would be nothing wrong with giving WFCO a test run. First trip let the battery get down to 12.2 volts and fire up the generator. Voltage should steadily climb to 14.2+ volts over 20 to 60 minutes. Otherwise time for a converter swap. WFCO is notorious for just charging at 13.6 volts regardless of the description in the operating manual.
I recommend this test for anyone that has a WFCO and charges the battery using a generator.- Ed_GeeExplorer IIAccording to the product description of his current charger converter, it does have Bulk, Absorb, and Float stages of battery charging. It also has battery type selection for wet, AGM, and Gel type batteries. It appears that he does not need to replace his existing charge converter.
- defrostExplorer
Lwiddis wrote:
defrost will get back to us.
Dug through the rig and found the converter hiding behind a panel, lots of fun :) It is a WFCP 75 Amp WF-9875. I am going to replace it with Progressive Dynamics PD9270V. Thanks for your help! - LwiddisExplorer IIdefrost will get back to us.
defrost wrote:
Yes. A low voltage slow charge will chronically undercharge an AGM and result in premature loss of capacity. WFCO is notorious for just charging at 13.6 even when described as a 3-stage converter. Still need to confirm what you have.
Is the concern with the existing converter that it would charge at too low of a voltage?- LwiddisExplorer IIUnknown without brand and model.
- defrostExplorerIs the concern with the existing converter that it would charge at too low of a voltage?
- Keystone? Probably a WFCO and yes it is best to replace.
You need a converter that will consistently charge at 14.4 volts when needed such as Progressive Dynamics.
http://www.bestconverter.com/Progressive-Dynamics-Converters - Ed_GeeExplorer IIIt would be helpful to know what model charger you have. Most relatively new ones have capability to switch battery type. In my opinion, most Wet cell chargers will not be unsafe to charge AGM types....but the slight different charge algorythems may shorten the life of the AGM batteries....
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,367 PostsLatest Activity: Apr 30, 2025
