SoundGuy
Oct 11, 2016Explorer
big_murph_279 wrote:
I'm in the early stages so I think I'm going to inspect my trailer this week and see what kind of space I have and where I could put the inverter and cables.
I suspended my 1000 watt PSW inverter in our trailer's front pass through storage compartment (10 pics) where it's out of the elements, not taking up space that would otherwise be needed for storage, and is within reasonable distance from the battery. As you can see it's quite easy to protect any 120 vac cable you may want to run along the underside of the trailer from where the inverter is located to where you want to connect to a dedicated receptacle.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,353 PostsLatest Activity: Feb 14, 2025
