I need to replace the upper gasket on my bedroom slide and I need to take off the Awning on the slide to get to the gasket. How do you take the roller off so it doesn't retract and I can get to the mo...
Here is how I did it. With the slide out, I got on a tall ladder and pulled the awning out of the roller as far as I could. Then I used one of those stout spring clamps to hold the material. The clamp was pulled snug up against the roller assembly. Did this on both sides. Then pull the slide in a foot or so. Use something to prop the awning material up and crawl under if you are small like me.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,353 PostsLatest Activity: Feb 14, 2025
