Chad_Heiser
Nov 29, 2017Explorer
allen8106 wrote:
For only two panels I would wire them in parallel and forget the MPPT controller.
My recommendations:
Tr-Star TS-45 Controller
Magnum MS2012 inverter
Bogart TM-2030 Battery Monitor
2 Crown 6v batteries wired in series
These are good recommendations. However, if going with a Magnum inverter, I would use the Magnum BMK battery monitor instead of the Bogart Trimetric. They are both good, but the Magnum has more options and integrates with the inverter remote (so less to install).
Crown batteries are very good, but if you are looking for a less expensive quality battery, take a look at Fullriver.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,351 PostsLatest Activity: Jan 13, 2025
