sgfrye
Oct 04, 2018Explorer
Artum Snowbird wrote:
Many of us use Costco 6 volt batteries. I have had excellent luck with them.
They are taller than the 12 volt batteries, so be sure you have the vertical space.
Traditionally, deep cycle batteries and marine batteries are designed to run a slow discharge for a long time. If your pontoon boat batteries need to be deep cycle, or if they are suited better to a starting battery depends on the usage in the boat. I have used truck batteries in my boat for years as they just start the motor and are not drained down slowly. They also have a 7 year warranty compared to 18 months for a deep cycle marine battery.
Yes agree
I have cranking battery for motor and use deep cycle for trolling motor and electronics
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,353 PostsLatest Activity: Feb 14, 2025
