ktmrfs
Oct 04, 2018Explorer II
garyemunson wrote:
Arranging a hold-down for 6 volts can be a challenge. I use these hold downs with threaded rod run at a 45 degree angle. My tray has a lip one side that the bottom of batteries rest against. The hold down goes on the far side of the battery and the rods run towards the lip.
https://www.golfcartking.com/yamaha-gas-battery-hold-down/
A watering system is also helpful as many RVs don't provide much access from the top to check water level.
https://www.amazon.com/Flow-Rite-RV2000-Pro-Fill-Battery-Kit/dp/B001FCAXT0/ref=sr_1_2?ie=UTF8&qid=1538652441&sr=8-2&keywords=battery+watering+system
several mfg make boxes designed for 2 GC-2's either mounted lengthwise or side by side. nice polyethelyne boxes.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,353 PostsLatest Activity: Feb 14, 2025
