Still_Searchin_'s avatar
Nov 29, 2015
Titan SideKick in-bed fuel tank install
December issue of Trailer Life has an article on this 15 gal. auxiliary fuel tank, which I purchased. Anyone else installed it?? The bracket on the narrow end of the tank that goes over the wheelwell is 2 inches from the side of the pickup bed and I'm thinking I need to put a wood block there to screw the bracket to, but may have to drill through to the outside of the pickup bed to mount that block. Anybody else have this issue??
1 Reply
  • UPDATE: Got it installed. the upper brackets do extend to the top rail of the pick-up bed as they are attached to the tank via a sliding slot. My challenge was that I also have a canopy whose fiberglass bottom edge covers up the top pick-up bed rail. I put the bracket between the rail and the fiberglass canopy overhang and used bolts instead of the provided self-tapping sheet metal screws. The tank cap is vented and can leak a little gas if tank filled to the top.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,399 PostsLatest Activity: Jan 20, 2026
