walker111's avatar
walker111
tv mounting bracket
Hi
Time to put a tv in the toyhauler garage and have a question. The template on the wall is a small square about 4 by 4 inches. Max tv is 32". All the articulating arms I find for the tv have the mounting bracket spreand out over about 10".
How did some of you deal with this?
Thinking maybe to mount a piece of wood to the area designated for the wall to stud and then use screws to mount the arm to the wood??
Thanks
  • Thanks all. Found full motion bracket arms regular 124 bucks on for 68 at Visions her locally. Bought two as I will change out the one in the main room so we can enjoy the recliners also.
    Salesman was so good I bought a 32" Samsung smart tv for the garage as they were 110 bucks off to! Figured with the savings I owed myself a few cases of beer for hopefully the installation this week and the maiden voyage next!!!
    Thanks all.
  • tenbear wrote:
    Here is how I mounted my TV. Note the arm takes very little space on the wall. I bought it at Amazon.
    Of course the TV is only a 22" and weighs less than 10 pounds.
    Your latch makes by bungee cord look amateur. ;)
  • Here is how I mounted my TV. Note the arm takes very little space on the wall. I bought it at Amazon.
  • I went to Lowes and purchased a 1/4 sheet of 1/2" nice grained plywood
    I stained and mounted this on the area for the TV (after locating the studs. Works and looks good.
  • Looks good. Any idea if the area with the template on the wall had aluminum stud or is there some a block of wood there behind?
    My toyhauler is in storage so not sure.
    thanks again.
  • "Thinking maybe to mount a piece of wood to the area designated for the wall to stud and then use screws to mount the arm to the wood??"
    Ding! Ding! Ding! That is the best way!
About DIY Maintenance
