rambleonrose's avatar
rambleonrose
Mar 24, 2019
Vinyl flooring - plank or sheet??
Hey folks
As soon as the weather cooperates and we can seal the roof, a new floor goes in!
We're wanting to go the vinyl route, but with all the research I've done, I can't find enough info on what's better for an RV - vinyl stick planks, or the more traditional sheet.
I have seen a few pics here where the sheet split - I'm in upstate NY, so weather is a big factor to my decision.
But.... how's that vinyl plank for moisture control? Was leaning towards sheet because there are no gaps, but I shudder at the notion of all the work and then a crack after the first winter! I like the idea of the plank/tile installation, as it seems way more familiar to me, having done floating wood floor and the like, but I'm worried with the temp expansion/contractions the gaps will be bigger, and any spills can wreak more havoc.
Also, regardless of type, going on top of particle board sub floor, is there a moisture barrier to put down as well?
Any tips or tricks on either of these would be extremely helpful for our decision!
TIA!
About DIY Maintenance
