rvshrinker
May 08, 2024Explorer III
OK I figured out how to remove the cap and check the screen. It had a fair amount of plastic debris in it, I cleaned it out and reattached.
I drained the pink from the winterizing tube, filled with water, dropped in a bucket of winter, turned valve to witnerize, ran pump. nothing. I can feel the pulsating and a slight suction on the end of the tube but it’s not moving any water.
So I conclude that the gap, leak, or block is from the pump onward, as opposed to from the fresh water tank to the pump, because otherwise I would get suction in the winterizing position and I don’t.
Am I on the right track?
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,352 PostsLatest Activity: Jan 20, 2025
