lee_worsdell's avatar
lee_worsdell
120/240 honda 7000
This summer I was told by a buddy to buy a adapter on my 7000 Honda so I could run on the 120/240 plug. I ran my 50 amp cord right into plug adapter. what or if is the advantage to that. Or do I just use the 30amp on 120v only. Not very good with power issues lol
  • 120/240V 7000W max. (58.3/29.1A) 5500W rated (45.8/22.9A)
  • Yes I did pop a breaker once but I had everything on to test it. Duel fridges,2 ac, water heater ,and lights . Tv and what ever else I could find to turn on.
  • If you plug your 50A cord into an adapter then into the 30A 120V plug on the generator you only can utilize 3600 watts (amps x volts = watts) of the generator capacity. Utilizing the 120/240 plug allows you to utilize the entire capacity of the generator, although that brings the potential to overload the generator, since a 50A RV can potentially draw more power than a 7K generator can produce.
