15" vs 16" tires question
kopy_kat
new rig came with really nice 15" wheels & tires--but I see some have 16" tires--any advantage to 16" size?
2013 Flagstaff 8528ikws---"Camp MiMiPaPa"
6 REPLIES 6
HD_Hauler
If the trailer comes with 15" tires I recommend you keep them on there if the trailer is under warranty, changing them would void the warranty. After the warranty I would go with the 16" tires because of the load rating, but be carefule of the height under the fenderwell of a possible slideout because when the trailer bounces along with your loaded gear it maybe leaving you with damage of rubbing thru the fenderwell.
2000 Volvo 420, 370 ISM Cummins,
10 Speed, Single Axle
2001 5th Wheel HR Presidential SKT 36.5
Me_Again
Chuck&Gail wrote:
16" gives you more choices in tires.
Personally I have put over 200,000 miles on various 15" NON-CHINESE ST tires. Only issues have been a few repairable nail, punctures. They work ok for me.
I replace tires if they wear out, or get to be 7 years old per DOT code. Often those two events are nip and tuck.
I balance tires, do not overload them, and as said above I do not use Chinese tires. Only 15" choice I know of at this time is Maxxis.
Your experience confirms that they OK on smaller lighter trailers. My one slide 96 26' Terry went on the same set of OEM LRC 15" Marathons until I traded it in the summer of 2004.
Chris
Chuck_Gail
Chuck
Wonderful Wife
Australian Shepherd
2010 Ford Expedition TV
2010 Outback 230RS Toybox, 5390# UVW, 6800# Loaded
Not yet camped in Hawaii, 2 Canada Provinces, & 2 Territories
I can't be lost because I don't care where this lovely road is going
wandering1
15" trailer tires are prone to blowouts.
HR
Ivylog
Fewer blowouts with 16".
Upgraded with a 08 HR Navigator 45โ€™...
Me_Again
Your really nice 15" tire are most likely cheap ST tires. It is hard to fine a higher quality 15" tire to carry the required load. Going to 16" wheels opens you up to lot's of choices.
Run what you have to two years and then get serious about doing an upgrade. What make are the 15" tires.
Chris
