Nevadastars's avatar
Nevadastars
Question going from 15" to 16" tires
I will be upgrading to 16" but am a little concerned about distance between the front and rear tires. With the current 225/75/15's, I have roughly 4 1/4" clearance between the tires. With 235/85/16's I figure there would be 2.5" which doesn't seem like very much.
There is also the 235/80/16 size which is not quite as tall and would have about 3.4" of clearance. I prefer the taller size because the trailer is a little nose high with the stock tires and the 235/85's would help level it. What is the usual clearance with that size tire/wheel combination. Thanks for any help.
