PArver2
Jun 05, 2018Explorer
1999 Alpenlite Window Replacement
I have a 29 ft RL Spyglass Alpenlite. The drivers side rear window was cracked (abt 8 inches) in a recent storm. You can catch your fingernail on the outside of the window but not on the inside. I am going to assume that at some point going down the road I will hit a bump and loose the window.
Any help on finding a source for a replacement would be greatly appreciated. On the window is the following info; Panel Saftey Glass, Solid Tempered, AS-3 DoT 322 M228 (or 6 not sure) 7-98.
I measured from the outside rubber seal to rubber seal, 35 1/2 by 31 1/2.
Thanks in advance to any help that can be provided.
