calstar
Mar 31, 2017Explorer
1st time 5th wheel owner sliding bar hitch question
I've had a truck camper and decided to go to a 5th wheel, found a good deal on one, bought it. It was 200miles away so I took my car rather than truck to see it, now will return to get it. It comes with a sliding bar hitch which I removed it from their truck and will now install it on mine. Heres my question: This hitch has a non-tilting plate(side to side), are these a pain to connect if the truck and 5th are not on level ground, must they be on the exact same plane to hook it up without a lot of hassle? I ask because if these are problematic I am not against getting one that has a small amount of side to side tilt and save myself the trouble of installing the one that comes with it and then realizing that I need/want a tilting type(which I would then have to mount a hitch for the second tme)
thanks, Brian
thanks, Brian
