rockwind1
Mar 25, 2014Explorer II
2005 ragen rage'n M 3005 FA FIFTH WHEEL TOYHAULER QUESTION
I JUST BOUGHT THIS, ORIGINAL OWNER REALLY PRETTY CLEAN. CHECKED IT FOR ALL THE PIN BOX ISSUES AND FLEX, SEEMED FINE. OWNER SAID RAGEN HAD FIXED IT UNDER WARRENTY BEFORE THEY SOLD OUT.
QUESTION IS, THE METAL TAG WITH TRAILER WEIGHT RATINGS AND STUFF SEEMS WEIRD
IT SAYS GVWR 14,110 LBS
DOES NOT GIVE AN UNLOADED WEIGHT
SAYS THE AXELS ARE RATED AT 6000 LBS
OBVIOUSLY, THAT DOES NOT ADD UP.
THEN ON NADA, IT SAYS THE AXELS ARE 5280.
I BOUGHT THIS TRAILER WITH THE ALUMINUM SIDE AND 30 FT Length BECAUSE I THOUGHT IT MIGHT BE LIGHTER, MAYBE IN THE 8000 LB DRY WEIGHT AREA. I WONDER IF THE FACTORY REPAIR TO FIX THE PIN BOX AND SAGGING WALLS ADDED A BUNCH OF WEIGHT?
ANYWAY, I JUST WANT TO KNOW THE DRY WEIGHT AND MAX LOAD WEIGHT IF ANYONE KNOWS. LOOKED ALL OVER THE INTERNET, CAN'T SEEM TO LOCATE IT.
THANKS FOR ANY HELP.
