fireman174na's avatar
fireman174na
2013 Raptor Fuel Station Fuse Location ?!?
Just needing a little guidance from those wonderful people who have had the gear problems with the fuel pump on the fuel station with their toy hauler. Specifically, I have a 2013 Keystone Raptor 30 (Travel Trailer). The repair has been done, yet I still cannot get power to the switch. Anyone want to enlighten me as to where in the world this "in-line fuse" might be. The battery is only 26 feet away, and there is no in line fuse on that end.
  • On my 2 Voltages and the previous Rage'n, the fuse was behind the switch/gauge panel buried in the wiring.
  • fireman174na wrote:
    Can you clarify the pump compartment you are speaking of? Gas pump or water pump area? I cant find anything around the gas pump and/or gas pump switch. Also, the battery compartment area is a no.
    My fuse is behind the compartment and up toward the frame that contains the fuel pump and hose.
  • Can you clarify the pump compartment you are speaking of? Gas pump or water pump area? I cant find anything around the gas pump and/or gas pump switch. Also, the battery compartment area is a no.
  • The only other fuses I know of are by the batteries. But as mentioned there may be some underneath by the pump.
  • The fuse for mine is under the pump compartment. Had to crawl under to find it the first time. Was 20amp, now 30amp.
  • I imagine it's changed but on my 2005 Raptor there was an inline fuse just off of the batteries. It hung sort of behind the battery and had I not been shown it I probably never would have noticed it was there.
  • Unfortunately, not in mine. Every fuse in the box is good to go, and the previous owner actually has them all labeled. Of course, none labeled anything close to "fuel pump." Likely going to do it the easy way at a campground with full service technicians on site next week. Pay the $35 to have them find it for me while I sit on the beach ;)
  • In my Keystone Fuzion of about the same year, the fuse for the fuel pump is located in the fuse panel with all the other 12V fuses. No other fuse located anywhere in-line.
