Ctrueit's avatar
Ctrueit
255rlds wilderness advantage
I have a 2004 wilderness with double slides that aren’t working. I’ve eliminated motor failure and am currently looking for location of slideout relays. Does anyone know where they are located?
  • Thanks found relays/controllers under step to bunk and replaced and both slides now work perfectly
  • Is yours hyd or gear operated.
    The Wilderness I had some years back had hydraulic operated slides.
  • Have you checked the circuit breaker near the battery? It should be within a few feet of battery, and may be on inside pass through wall.
    Jerry
  • Have checked power is good motors work when hot wired, power to slide switch is good has to be relays or controller that are bad
  • it would be unusual that both relays would be bad. Trace the wiring from the battery to the area near the pump if they are hydraulic. Be sure the battery is charged. The convertor may not produce enough power to run them without a good battery.
    B.O.
