BurbMan wrote:
It's the tires. A load range E tire has a rating of 3042 lbs @ 80 psi, so the axle is limited to 6084 lbs even though the axle itself is rated at 7k.
So 3 axles is a total of 18,252 plus whatever on the hitch/pin plus a safety margin for loading...side-to-side and front-to-rear, depending on how the rig is loaded will not distribute the load equally over all 6 tires, so if running at max weight it's likely that at least one tire overloaded and one is underloaded.
If I recall correctly, the Grand Design Momentums are coming with LR G tires.
Even so, my LR E tires that I originally had were good for 3,420 which brings you to 20,520 plus pin weight.
For the OP - I wondered the exact same thing. I think this would be a good question to send to Grand Design. My guess is it has to do with either the pin box (could be a 20k pin box) or the frame.
I wanted a GD but couldn't get by with the 3,500 lbs. of cargo carrying capacity in a 43' toy hauler. It didn't make sense to me.
