vicmic83
Oct 25, 2015Explorer
Jonny637 wrote:
Yes, that's the one. Mine even looks a little rougher. Instead of upgrading, what do you think of buying complete power center/charger/converter? Looks to be same price as upgrade.
I just upgraded my whole converter to a BPC4-60 Boondocker.... Patience.
You need to buy some Female Flag Disconnect Terminals. This is needed for the 12V wires to fit in the small channel above the fuse board. Hint... If you 12V White commons are on a separate bar, you need to run a heavy gauge wire to the back of the Converter Unit. The wire will be the same size and gauge as your the Wire from the Negative terminal on the battery. I found on my original Converter the factory had 14 gauge wire going to a 20 amp breaker instead of 12 gauge. Glad to walk you through it. I think I paid $215 at best converter. I think Camping world will install it for a price. If you want to talk give me a shout.
R, M & V
I put in a new tankless W/H also.
About Fifth Wheel Group
19,007 PostsLatest Activity: Feb 28, 2025
